Nedregistrering!
Posted 22 December 2015 - 16:10
Posted 22 December 2015 - 18:20
Logikken har vært fullstendig fraværende i disse sakene, så fint at noe skjer!
De må gjerne fortsette med originale lys på amcars, men der vil vel selv frp møte veggen i EU...
Edited by Tahoechase, 22 December 2015 - 18:24.
Posted 22 December 2015 - 20:35
Men det er jo litt dumt at en nedregistrert Tahoe har mindre lasteevne enn Peugeot 308'en min. Lurer på om det går an å gjøre noe så den blir oppunder 3500kg.
Posted 22 December 2015 - 21:46
Posted 24 December 2015 - 11:26
hehe nesten for ille at bare mat handelen blir for mye for vekta for bilen.. hehe gir ikke mening i det heeeele tatt..
Posted 24 December 2015 - 13:19
På tide!
<script pagespeed_no_defer="" type="text/javascript">//=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty©)return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b{d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if( {var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject©}catch(P){try{l=new ActiveXObject( }catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e( ),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.offroad.no/forum/index.php?app=forums&module=ajax§ion=topics&do=quote&t=132094&p=1695721&md5check=3db93acb3c2a9c8b82d51377490af51f&isRte=1,WyQ3C4mRrQ,false,Q9Lqmjub0-s'); //]]></script>[q];++d){var>[q]+d[q])break;a+=d}b=!0}this.e&&(d=x+e(json.stringify(this.h())),131072>[q];++b)for(var>
Dem driver å jobber med det å, få godkjent orginale lys samt us hengere med el brems. Ved import må bil/henger være registrert min 6 mnd i usa.
I`d rather push my Chevy than drive a Ford.
Det finnes ingen dumme spørsmål, bare dumme
svar!
Posted 24 December 2015 - 23:26
Det er ikke norske myndigheter sin skyld at totalvekten på Sub og Tahoe blir lav ved nedregistrering. Det er produsentens skyld.
Posted 27 December 2015 - 07:47
Mr.C
Posted 27 December 2015 - 12:14
Ja, det kan man si. Men samtidig ble disse Tahoene regget til 3560, og da bør de jammen tåle 3490 og.. as is...
Som 'lastebil' KUNNE man også laste den til f.eks 3490, men gud forby.. Den vekten kan absolutt ikke stå i vognkortet som totalvekt... .?? Vel, litt vanskelig å servere en fornuftig forklaring på det vel, norske myndigheter??
Edited by Tahoechase, 27 December 2015 - 12:20.
Posted 29 December 2015 - 22:51
Tror vi bare får være glad for at de kan nedregistreres så får de som er interesserte se om det går an å oppgradere vekten. Mulig det går med hjelpefjærer. Hva som gikk når de var C1 er vel temmelig likegyldig.
Posted 30 December 2015 - 11:28
HVor står det at med de nye reglene blir lasteevnen på En Thaoe mindre enn på en Peugeuot 308?
mvh
B.
Sjølberging er alfa og omega.
Posted 01 January 2016 - 23:52
Det står i vognkortene. 308 kan laste 569kg og Tahoe klasse B kan laste 495kg.
Edited by Gurba, 01 January 2016 - 23:54.
Posted 02 February 2016 - 15:50
løfter denne igjen. har en Tahoe som var nedregga til totalvekt 3085kg noe som ble litt knapt med fulle bilen i unger, hunder og bagasje. var en tur innom vegvesene i dag og fikk registrert den opp i dag til 3499 kg. gikk knirkefritt. liten kontroll av bilen og en 30 min med parpirarbeid så kjørte jeg der i fra med nytt vognkort. etter jeg hadde vært igjennom "ilden" for min mor og de også inn med sin durango samme prosedyre. en kontroll av bilen og halvtime med papirarbeid. så var den også klasset ned fra 3505kg til 3499kg. vi begge fikk spørsmål om hva vi ønsket nye vekten på. vi valgte enkelt og greit 3499kg av den enkle grunn for og slippe noen form for missforståelser om man skulle bli stoppet og det hadde stått 3500kg. hvertfall ingen tvil når det står 3499kg. så alt i alt en meget fin dag. var tydeligvis flere som kom i samme ærend. hadde både silverado. dodge ram. og en nyere durango bak meg i køen
Edited by daffaen, 02 February 2016 - 15:55.
Posted 02 February 2016 - 19:03
Hei,
Hiver meg på tråden;
Det gjelder nedregistrering av -97 Tahoe 6,5TD, pr. idag registrert som personbil over 3500 kg. (Må altså ha C1 førerkort)
Jeg har lenge tenkt på å nedregistrere, har tidligere vært i kontakt med SVV, det eneste som tidligere har vært påkrevd ifb. med nedregistrering av dette chassi, har vært å bytte beltene.
Fra original type med (belte)rulle oppe og nede, til "euro"-spec belter med kun éi rulle.
Forrige dagen ble jeg fortalt at det fra nyttår er blitt forandring i reglene, dvs. at jeg ved å nedregistrere bilen til 3500 kg totalvekt, så er den mulig å kjøre lovlig på B-lappen, i tillegg så er det ikke krav om bytte av belter, nettopp fordi vekta er 3500kg.
Er det noen som kan bekrefte / avkrefte?
Prøvde å ringe SVV idag og igår, gav opp etter 30 min i kø, de ringte heller ikke opp igjen etter at jeg la igjen nummeret mitt....
MVH
S-A
Posted 02 February 2016 - 20:40
Edited by daffaen, 02 February 2016 - 20:43.
Posted 29 February 2016 - 02:30
hmmm. så da kan jeg dra med min 97mod silverado og registrere ned fra c1 nå???
må kansje demontere bodyliften å stikke innom biltilsynet, hvis det stemmer?
#17
Posted 29 February 2016 - 20:14
http://www.msn.com/n...iler/ar-BBmCxEI
Henger meg på denne tråden...
Det ser ut til, at 15 mars 2016 er eller kan blir en hyggelig dag for de med biler på "feil side" av 3,5t tillatt totalvekt.
- Bom satsene planlegges å settes ned fra lastebil takster til personbil takst (i følge noen som hadde undersøkt i dag).
Kan være greit å sjekke med sitt "selskap" om dette (endelig) faktisk skjer...
- Endringen skulle gjelde for privat registrerte kjøretøyer, ikke firma registrerte kjøretøyer...
#18
Posted 01 March 2016 - 13:14
Da mangler bare PKK og toppfart.
#19
Posted 08 March 2016 - 10:36
Edited by mr.chevy, 08 March 2016 - 10:37.
#20
Posted 08 March 2016 - 16:00
Du får nedregistert Hummer H2 til personbil under 3,5t så sånn sett burde det meste gå. Har også sett en 5-seter Avalanche 2500 med 8,1l som personbil under 3,5t.
